Hi everybody my A9 disconnect when listen music in my iPad a person what a idea thanks
Problem with A9
Probably not a good connection to your router. If your iPad and/or A9 is far from the router and/or if your router is weak/slow/old this is what will happen. I would suggest moving your units closer together if possible and also check that you have a "good enough" router. I strongly suggest you use a 802.11n router that has mimo-antennas. Good Luck!
