Problem with a lc2, advise please
Hi Guys
I have a problem with a lc2, when the light is tuned on it does light up (60w incandescent bulb), but it does not respond to touch or the beo4. What can it be? (there is no plasma tv nearby).
The fuse is also okay.
Any input?
Hi techtrino,
does the lamp burn a) at full or b) at reduced brightness?
Does it turn on a) immediately (as it does when connected to a standard power switch) or does it b) light up slowly?
It your answer is a) both times, I would assume the internal regulator (triac) has a short cut and needs to be replaced.
Hi Hagen
It is a both times, do you know if this can be replaced easily or does it have to go to B&O? And do you know how much it costs?
Hi techtrino,
unless you know someone with technical skills I fear you will have to go to B&O. And they will rather exchange the whole circuit board than repair them. No idea how much it will take.
