Probably a stupid question but one that must be answered to silent my friend :)
It's a stupid question but needs to be clarified.
Just silent my friend, please!!
Speakers;
From a music/video source, whether B&O or not, does sound get transfered in an analogue or digital way to the speakers?
Can't wait!!
Cheers
Mostly analogue.
But there are systems where you can digitally connect the speakers to the tv. But that's only possible with active speakers like the beolab 5.
Beobuddy wrote:
Mostly analogue.
Just to clarify slightly - "active" speakers means that the power amps are within the speaker cabinet and individual amps are matched to their respective drivers. To accept a digital signal then some form of DAC also needs to be contained within the speaker cabinet, as well as the power amps. In the B&O speaker range, only the BL5 is equipped to accept a digital signal - the other active speakers are not.
Other manufacturers also make speakers that will accept a digital input, even from relatively inexpensive PC "studio monitor" style speakers however, a digital input still relies on the quality of the DAC, amplifiers, drivers and cabinet design as much as any other speaker, i.e. a digital input alone does not necessarily imply "better".
Thank you for clarifying.
Job done, next argument please.
