Preamp for Beolab
Which brand does a preamplifier or better A/V preamp with trigger output for connecting Beolab ?
Try to look at Yamaha WXC-50.
Fine good idea for audio.
And any idea for AV ?
I'm using a Marantz AVR with preouts. It has a 12V trigger, but you can find cables with integrated downgrade to 5V trigger signal for BeoLabs.
I did it this way.
/forum/general-discussion-and-questions/surround-sound-with-beolab-speakers-and-none-bampo-tv
Guess there are many receivers like the Harman Kardon with a 230v socket turning on/off with the amp. Simply plug in a good quality usb charger and you'll have a 5V trigger.
Thanks for your input !
If found this thread:
/forum/general-discussion-and-questions/beogram-4004-fuse-value#post-1903459
about Canton Smart Connect 5.1! It seems a very good products ! Need to DIY to get trigger output.
