As subject indicate; is it possible to export/dump PUC codes from an existing BV11 (or V1)?
Possible to Export PUC codes from BV11
Export for what reason?You can delete your PUC from the TVIf using another NL TV you just download them to the new TV
Primary reason would be to explore and create your own PUC files for device which isn't supported or improve the existing ones and then of course the possibility of importing to BV which doesn't have the option to download the PUC codes.
Creating the codes should not be the biggest problem - they could be send to you from a dealer/technician.
How to get these loaded to a pre-BSys4 tv however, a bigger problem.
