Possible BV7 purchase.
Im confused? could someone please explain to me or give me an example of something they want to connect to BV7 with the SYS3 that they couldn't now? except for 7.1 surround sound or a projector screen which david dosent want to use anyway.
Beomedia?
It's like buying a new car realy.You wouldn't buy an end of the line BMW if you knew that in three months a newer model was coming out. I know that I don't want to connect a projector now but when / if I move house I will then have a choice of more options. It's a £6k TV I have to think ahead with such a large purchase.
Actually my local dealer has BeoMedia on his BV7 as i do and it works extrmely happily!! Also you are putting your BV7 in a slave mode which means you won't need the connectivity anyway as all the sources will be coming from the Avant master set. Its your choice but i dont want to see anyone pay upwards of 8 grand for somthing that could of done the same job for 6.
BeoSystem 3 has been on display in the US for about a year now, and connectivity aside, we are seeig much etter picture as compared to BS-1.  Some of the artifacts associated with 'film mode' are better managed, and over all it seems sharper and cleaner.  But that's what 5 years of R&D gets you I guess.
 I'm told that the BV-7 will break cover here later this month...can't wait to see it in person.
Hi there i have just purchased a second life MINT BV 7 32 c/w 7.2 ,  floor stand + beolab 3s....
fantastic deal..
what can i say.....#
I have a relitivley small lounge ( 14x 6ft) & by the time i have finished installing my lutron lighting + HC setup... it will be amazing IMHO..
my 3 yr old cant wait to see Nemo on the projector screen.... :)
I Got A Bv 7 Mk3 Two Weeks ago and the Picture Is Fab😁
Not had much time to watch it but everytime I do it looks so good!
Be even better once get time to watch some ps 3 stuff on it and looking forward to getting the Projector running as well.
