Possible BV7 purchase.
Well after derliberating about which TV to buy for our second lounge I have decided on a BV7 with a 7.1 speaker.I have read some threads about the film mode being useless and that it should be switched off, but is this the only bad point about the TV?
What do our fellow members who own a BV7 realy think about it? Is it a good TV and is it worth the money?
I think the BeoVision 7 is a good decision depending on how large your second lounge is, mine is quite small compared with our main lounge. You may wish to wait for the next version of the BeoVision 7 with the BeoSystem 3 chassis
i've seen one in the flesh and it's a stunner
amazing picture and beautifully made
personally , i'd leave the speaker off as it's the only thing that upsets the design and use some beolab 6ks etc as left and right audio
does the new one have hdmi yet ? and freeview
once they're standard it will probably be the best tv in the world
Thanks for the advice.Do you know when the new BV7 is due to be launched?
Yes I think you are right. The 7.1 underneath is not great looking. If I did use Beolab 6's as left and right speakers would it sound ok when I watch documentries or programmes with alot of talking?
i don't see why not , i have a pair of beloab 6ks connected to my avant32 dvd and you can simply select speaker 1 , speaker 2 or speaker 3 for different sound modes
speaker 1 gives tv only
speaker 2 is 6k's only
speaker 3 is a combo of both
the 6k's are surprisingly good speakers imo as long as you don't expect earth shattering bass , plus they look much nicer than some of the weird stuff bno are coming out with recently
how it is possible if speaker below the screen is left out of combo?
I have, for a year now, a BV7 and I am very satisfied with it. Just get it, you won't be disappointed. The only thing I strongly recommand you is not to buy it right now, but to wait for some months, because there has been talk about an upgrade for some time, and it would be a pitty to miss that one.
About the speakers, I have to say the following: the BL7.1 is a superb speaker, with crystal-clear sound, very deep and powerfull bass and more power then you'll need. It's stereo image is good, but due to the size of the speaker, it is somehow reduced. For a second lounge, the speaker is more than enough, even if you want to use it for music-listening.
IMO, the worst thing you can do is leave the 7.1, as a TV without center speaker looks and sounds like crap and above all because the BL7.1 is the best stereo-center speaker you can get.
You can connect center, front, rear speakers and a subwoofer to the BV7.
The speaker modes are the following (if you have more than a center speaker):
  • speaker1: only center speaker
  • speaker2: only front speakers
  • speaker3: center and front
  • speaker4: front and rear (double stereo/ enhanced stero)
  • speaker5: center, front and rear (DTS or Dolby Digital)
Hope this helps. You can PM me if you have other questions.
Thanks Tom,
 I visited my B&O dealer this morning to take a look at the BV7. I like the look of it and your right the 7.1 did sound very deep and purposefull. They put Pirates Of The Caribbean on and it sounded great for one speaker.
I have no TV in the room at the moment so its hard to wait for the upgraded version to arrive.
We shall see.....
I have owned a  BV7-40 (with BL 7.4) since about a year now and am very much satisfied with it. I think the price-performance ratio of BV7 is very good. I have a red-colour version, which matches the furniture in the room, and it always causes a "wow" effect when my guests see it.
