Popping sound on specific frequencies of male voices - Beolab 18/19
I just bought a brand new system with Beolab 18 and 19 - connected with BeoCore, and have an intolerable popping sound with deep male voices.
In general the system sounds amazing, but with specific voices (like that of George Clooney), the room is shaking with the random pops. Its not just isolated to the typical B and P mike pops, but more like hitting a specific frequency.
The sound appears both when using analog input on the BeoCore and over wireless AirPlay, and everything is connected with B&O powerlink cables. The pop sound comes from all speakers (18 and 19). So i suppose the problem can be isolated to something in Beocore and wiring?
Any ideas how to troubleshoot?
Just wondering how exactly you have the core wired to the speakers.
Usually when a BL19 is added to BL18s and a core they would be connected using WISA via a transmitter 1 which would do the sound processing/crossovers between the speakers.
Have you tried placing the BL19 in another (or more) different location(s) in the room?
It's all daisy chained with powerlink - so ethernet cable from the core to left speaker, then left to right speaker and then to BL19 subwoofer. So no transmitter in the system.
No - can try. But, the sound can be heard on all speakers clearly when i put my ear close to the units.
Just curious, if you unplug the BL19 entirely, do the two BL18s still pop?
Any what are the settings on the BL19? In particular how is the low pass filter set?
I didn't try this - but will. I didn't try disconnecting the 19 because i hear the pops clearly in the 18s when i have my ear close to the units. But it wont hurt to try and disable the 19. Ill get back. And thanks.
So, i tried setting both gain and low pass on highest and lowest - the BL19 and BL18 still pop.
