Good morning guys,
Today was a lucky day (maybe): I've bought a bag full of little things B&O!
The thing is I have some question on how I can check if they're working or not, and for some of then what I can do with them. Here we go, appart various master link and power link cables I got:
A Beocenter 2 "black box" with main cable:
- I suppose it's useless without the head? EDIT - Yes
- Could it be pin protected? EDIT - Yes
- Any way of checking something without the head? So far the answer is still no
An ML/MCL converter, type 1651, no IR eye and Beolink passive, type 1656, no IR eye.
- How to check them? EDIT - tried with Beosound -> power link -> to Converter without IR eye -> to passive speakers : Didnt work! EDIT - It works, be sure to use a fully wired 8 pins powerlink cable (thin cables have 8 pins but not all are actually wired!)
Last but not least, A Beosystem 3 Type 9600, with two little IR pearls wired on jacks.
- What MK is that? couldn't find on the forum. EDIT - Looks like a MK1.
- Could it be pin protected? EDIT 2 - No PIN protection on MK1.
- How to check it? EDIT 2 - It need an IR eye to startup.
Thanks in advance for any insight.
