Hello everyone,
I have a pair of BeoLab 6000 and I would like to be able to stream music over WiFi to the speakers. I know that the "B&O" way would be to get a Playmaker and indeed I wouldn't think twice about it... IF it had a better design. But in its current form, I can't say that the Playmaker is something that I would proudly display on my home and I don't really care for DLNA connectivity since I only use AirPlay anyway. So why spend close to five times more for something that will remain hidden anyway?
My only "concern" is about sound quality since I read somewhere that (the newer versions of) Airport Express use a low-quality DAC and thus that Playmaker has a significantly improved performance over AE (if you use the analog connection). Since I have no way to test both, I would like to hear your opinion on the matter. Playmaker is not that expensive (in B&O terms at least) but why not save if possible?
Thanks in advance for your help and insights!
PS: I don't really care about the ability to control the speakers with a Beo4/5 either, just the sound quality
