In January I bought a pair of white BL12-3s which I´m very happy with. For ease of use I also found a used Playmaker MK2 and bought that too. It turned out to be exactly what I needed. Very happy with the option to switch track and also adjust speaker balance from the Beo4.
Some two weeks ago the sound suddenly disappeared from the right channel. The Beolab still turned green when on and red when turned off. Of course I tried adjusting balance, factory resetting the playmaker and switching the “speaker role” to left for the right one and right for the left one. When also this indicated that the issue followed the playmaker I connected it to a pair of Beolab4000 with other cables and also via line in on the playmaker to rule out airplay transmission as the issue.
After this I concluded that the playmaker was dead (on the right channell). I was then super happy to find a playmaker listed and sold locally for 50€, so I picked it up the next day. It all worked well even with long distance to the router and the 2nd playmaker being a MK1.
However now after little use during a bit more than a week I have the same issue with the new one. Only difference is that the sound level is now also very low on the left channel, and again dead on the right channel. Same test procedure gave the same result, the playmaker is damaged.
Now to my question.
-has anyone else had the same experience with the playmaker?
-has anyone had the experience with any sound master that a Beolab speaker “kills it”?
Thanks in advance
//Goran
