I'm running a Playmaker with no problems connected to my HP netbook with iTunes. However, my iPhone connection is very temperamental. Although it recognised the Playmaker it will often dump the connection as soon as I press play. At other times when it does connect it will hesitate mid-song, and eventually fail or cause the Playmaker to go into error mode. Any ideas why this would be? I'd think it is an iPhone problem as the Playmaker runs perfectly when fed by the netbook.
Cheers,
Patrick
