Play V1-32
Hello all
If I swap out my beovision3-32 for a V1-32 would I still be able to pull master link sound and accept standard definition TV from the modulator in the bv7 in the main room?
I assume the moment would be able to push : pull sound to the v1 once the it has the software update?
Cheers all
I didnt think the v1 had masterlink or could act in the same way - if that's the case maybe an 8-32 with the system board included
The V1 has neither masterlink connection nor the ability to connect to link video. I think (but not tried) you can listen to audio sources on a V1 if a Masterlink to Network link convertor is added.
Steve
You could do it, using a BeoLink Video and Lintronic Box Digout connected to the analogue AV connector of the V1.
I'm using it this way
hfat
