Plasma protected infra-red eye
Hi folks-
I mounted a link room infra-red eye and then later a plasma television and now the eye wont work with the tv on.  I've read previous posts but just want to clarify a couple of things.  Is the Lintronic eye available from B and O stores or locally in the US?  Are the new infra-red eyes really plasma protected now?  My dealer doesn't seem to be too knowledgeable on the subject and says the filter is not available anymore.  Is there a filter I can make myself and put over the eye?  Any ideas?
chris
The B&O part number is 8087030. I bought mine via Lintronic and it works fine with my plasma.
Working on the Lintronic pricing it's around $168.00 USD. Don't know what the dealer price is though.
Hope this helps.
Peter
That's is very expensive !
If i remember correctly, i paid about € 45,- at my local B&O dealer.
(same part number)
