Peripheral unit controller tables
PUC, to you and me.
Hi I have just purchased a Humax Aura and want to plumb it into my television using the PUC codes which I can see for this STB I can down load the relevant codes, but I am not sure which buttons will do what as there seems to be more buttons on the Humax stick than on my BEO4.
Previously I have seen "Peripheral unit controller tables" that explain which button to press to do specific thing.  Are they still produced, if so, has any one got a table for a Humax Aura?
Thanks in Advance
Gary
When the source is activated, pushing MENU on the beoremote should bring up a menu on the left screen side, that shows you which button should be used for which original functions.
Thanks Mil
