Penta Speakers
Hello again guys,
Another evening in my B&O room..............
Listening to my favourite tracks when all of a sudden I'm drawn to how unclean my Penta's are.
So, does anyone know a nice fix to clean the metallic panels?
I've done the car polish but it still leaves streaks.
hey hey
what if you don't "do" babies ????
as in my babies are 16 & 18
Keep the rest for when the grandkids come along - won't be long now😁
Chris.
So daughter comes along with her "make up wipes" and says try these.............
not bad but still leaves "stripes"
come on guys there must be a "cure"
what about "t cut" ????????
Try glass cleaner (I like Mr Muscle) and a microfibre cloth. It always works for me.
Some members here recommend applying a coat of baby oil after cleaning to give a good sheen. I have never tried this, though I can imagine it gives good results.
We did what was recommended somewhere on this site......we got the car polish with the "bug remover"...it's a very, very light rubbing compound....and didn't apply too much pressure....then finished with a polish only....they came out like new...
 my damn displays still dont work though....
Steve, if you just want to clean them and don't need to do a light polish like for Rizzo's suggestion, go to a kitchen appliance store, or the kitchen section of a home improvement store.  Ask for stainless steel appliance wipes.  They come premoistened with some mineral oil which removes dirt and finger prints from the steel.  Then use a damp cloth to wipe off any excess oil if you need to.
Austin
"Star Clean"is the answer for cleaning our Penta!
 I promisse that this is the best  product ever. made!  After a  very easy polish, your  Penta´s look like brand new (and that with 100%  guarantee! )
Buy Star Clean online here link  The price is only 20 $.
link
