Help needed,
I have just realise that the display on one of my Speakers have stopped working...Does that meant the display is gone or is there a way I can fix this issue.
Please help....and thanks in Advance.
Help needed,
Just to rule out the most obivous, You havnt changed the switch under the speaker? There is a small switch that say "Audio/Video". If you have been changing some cables you might have moved the button (I did that once hehe).
Hope its this easy
Jesper
Sweden
Thanks Jasper, I will check that tonight, I might have done that, has I have been moving things around...lately
Jasper,
Thanks, it worked again, it was the switch as you suggested...Thanks
MT
