All the capacitors and resistors look good on the PCB 2 board....we replaced all of the Transistors (except TR 3....couldn't find one)....
Same problem persists...turn it on...and light goes from red to green for 15-20 seconds...you get some sound for a 1/2 second when you switch from auto to left....
Could this be the NTC 330k ohm...resistor on the PCB 1?? That is clicking it off cause its bad and think its hot???
Ideas???
