Second hand display's are few and far between. They can be ordered at B&O, but it'll cost you. I've never worked with the Ridax display's, so I can't comment on them, nor on how easy or hard it is to fit them into the Penta's. Regarding your other steps in upgrading the Penta's, I've got a very different opninion then that of the topic starter.
Directly soldering the wiring to the unit with silver soldering, will not give you any audible inprovement. It is stated that the resistance of the connectors is very high, and that of silver solder is very low. This is true in a way, but the differences are to small to be heard. Fact of the matter is, that altering the resistance does in no way alter the soundquality. The resistance of the connectors is absolutly lineair in the audiospectrum, just as the silver solder is. The only influence a lower resistance has, is that he speaker will play measurably louder then the connector version at a given input signal when using silver solder. But the difference is very small and can easily be corrected by turning the volume up a very tiny amount. The only thing you will accomplish, is that the resoldered Penta unit is just a minute tad more sensitive then the connector version. But given the fact that Penta's are a relativly sensitive speaker already, you gain no substantial benefit. This we tested in many different ABX hearing sessions at my former company. But that is just my 2 cents.
Adding or replacing your amplifier will also not give you much improvement. It is often stated that the Penta's need a very beefy amplifier to really shine. I've got no idea who started that statement, but it is ridicilous. The Penta's are very sensitive for a cone-speaker system (91 dB versus 86-88dB for an average speaker), so no need for power in that respect. The impedance curve is also very amplifier friendly, so no need for power there either. I drive a set of Penta's using a 12 Watt OTL Tube amplifier at home, and this combo can play loud enough to make windows rattle. Ok, the Penta's are capable of earthshaking volumes, if you drive them with a 200 Watt per channel amplifier, but I doubt one will ever reach those volumes in normal live in there home setup.
But hey, those are just my 2 cents on those matters. I am a trained electrotechnician, so I normally use to smile when audiophiles claim outragous improvements, which have no electronical or physical explanation what so ever. I just want to let you in on the other side of the coin so to speak. Believe who you want to believe, and make your own discissions.
Good luck with your modding project. Hope it works out for you!
