Penta High End- a great projekt.
What to do:
Change broken midrange speakers, remove the useless and sound destroying "push on" terminals and make silver soldering, and maybee make outside speaker connektion for use with a new extern amplifier
In this tread; olso how to change tweeter to a modern type and much more
Typical problem on all kind of PentaΒ΄s, - new or old old - BeoVox or BeoLab -The midrange are broken
How to remove grill. Place two fingers on the cloth precisely where you can feel the clips, and then pull out the cloth , - then the lock release
Place the speaker on a table, and remove the grill (Remember to PROTECT THE CABINET against scratches!)
Change the midrange drivers and cut off the push-on terminals and make a real silver soldering instead (use WBT-0820). The connectors are made of some kind of cheap metal and not cobber!, (but they are easy to mount on a factory!)
They have a huge resistance and therefore not make the sound optimal. Remove them all.
Adjust the hook to the speakers if necessary.
Then do the same on the push-on terminals of on the bas and tweeter and make a soldering. For best result use silver soldering (WBT 0820) be carefull with the tweeter and dont use to much heat to long. Remember to PROTECT THE CABINET against scratches. the bass speakers can easely touch the sites of Penta
Use strips for protect lose wiring. If not, you will here them make noise when you play loud.
When finish with the soldering, replace the speakers again
Go to filter in button- now its getting a littel more difficult. Its possible to remove the print for getting more space if you like. A good idea is always to take lot of pictures, before you lost the tread..
Cut off all push- on terminals again and make real soldering .Notice that the wires to print is very short.
Now its sunday...π
If you want to use and another amplifier then change the speaker main wire to a longer one (you need 2 x 1 meter HI- END speaker cable - find a good thin type or drill a bigger hole in print). For best result, soldering the main speaker cable direct to the print.
The speakers wires inside the cabinet are made of pure cobber and sound absolutely okay . Once I have tried to change it to HIFI Supra speaker cable, but without any special improvenment. Therefore I canot see there are no need to change the original cables.
The new main speakerwire is drop down inside the old - now un-used amplifier, and coming out somewhere in of the buttom. Find the way you like best. Make then holes for new speaker terminal underneath, use the best speakers terminals you can find (yes I know, they are very expensive, but you can hear it!
IMPORTANT Remember to remove the main fuse in button of the amplifier and only leive the small fuse for the display,- it shall still work as normal.
Then its monday again.. π
