You ordre the midrange drivers at your normal B&O shop.
Dont worry if the labelname are different from the original.
The label name on the old one was Nokia!, now its no-name π but its the same speaker with the same spec as the "original") If its fits, there is no problem.(you will proberly only need to adjust the "hook "
You can see the name Nokia on the two old midrange speakers to the left, the others midrange on right site are new ones
