Unplug everything from the mains for "a minute or so." Then, plug in the Overture first, then the speakers. Should be ok.
B
B
i've left the speakers unplugged for a couple of hours, unplugged the ouverture for 10 mins, plugged back int overture then both speakers and still no display on one speaker.
Rob,
Is everything else with the speaker working normally? E.g. is the sound normal coming from the speaker? Is the speaker going to standby as it should? Is the red/green indicator light working correctly?
Perhaps there could be a slight loose connection with the display itself if everything else works as normal. Could try taking the cover off and just having a play about...
I've never heard of a display actually breaking down but I guess they could do, in which case a replacement display would be in order...
I'm not technical enough to know myself, but hopefully some on here does.
Regards,
In Pentas, the displays work completely independently from the amplifier part (they share the same mains transformer, but really nothing else). The displays are also powered on (technically, not visibly) all the time while the speaker is plugged into mains. There's a separate 40 mA mains fuse, but that circuit also powers the standby part of the amp - if the speaker itself turns on and works, there's nothing wrong with that.
Now either
I'm quite sceptical of something getting loose or shorted inside the speaker just by chance if you don't even move them around. One likely problem is a short / open in the Powerlink cabling, disabling the data connection. Pinched by a chair leg recently perhaps?
The display module has a couple of capacitors which I hear are sometimes bad. More likely in an old pair than a 3.
if i ignor the display not working everything works exactly as it should. the display (2 x cicuit boards) are good as i swaped them with the good speaker and it works as it should.
I sort of ruled out the cable as i used a brand new one after the fault happend, but then even new ones can be faulty, so i will swop with the known good one.
But if this doesnt work i'm gonna just strip them both down and start swopping parts.
I'll post an update if and when i find the problem part.
thanks to all for the info/help
plug between base / tower?
that was looking promising as the cables had been squashed abit so i rewired the damaged parts.
The problem is definatly somewhere in the base as i swoped it over with the good one. Ive put a link in to make doubley sure its not the fuses, swopped the front circuit board (with the swithes) still nothing. Checked the audio/video switch has continuity and works.
on the good speaker im getting 6v (i think) between brown and blue(??) at the plug that conects to the rear circuit board for the display but on the faulty one im getting 0.1v, so next guess would be a resistor maybe?
I have no idea of the colours of the wiring, but the DIN connectors are numbered as they always are (possibly molded in plastic beside the pins as well). The supply to the display modules comes up in pins 2 & 3 (there was an error in my above post). And it's AC, not DC.
And there are actually two separate mains transformers, the smaller one supplies the standby circuit (which is working for you) and the display from another winding. If you have isolated the fault in one of the amplifier modules, it really can't be much else than the wiring / connectors to the display, or a faulty standby transformer.
right ive had it apart again, checked all coninuity from the 6pin display plug to the base and all wiring is good. Ive got 12v at pins 2 & 3 and traced them back to the transformer to confirm, still nothing...
OK, so the display apparently works and has power... I believe it's time to try and find where the data gets lost then.
This is unfortunately a bit more involved (and difficult without the service manual) as there are some active electronics in between. What you might do is check the solderings of the Powerlink socket in the bottom of the amp - I presume you're using that since you have an Ouverture.
