Hi!
I wonder if the display on my Beolab Penta 2 will work when connecting to the Powerlink-output on a MX6000? And what will the display show?
(Penta is from 1988, MX6000 from approx. 1995)
Thank you!
//Johan
Hi!
Thank you!
//Johan
Yes it will work, just remember to chance it to video on the bottom panel.
shows TV-V.tape-V.aux..... channel and volume. I think
Nice, thank you!
Do you know if the MX6000 will work and fit with a motorized stand from a MX5500? The cable socket on the back of the two TVs should be the same, but how about mounting holes etc?
All MX tv's equipped with the 4 pin stand socket will work with the same stand motor and there are only two mounting plates, one for 21"TV's and one for the 26"TV's.
It should be noted that the stand socket on the MX4200 and the MX8000 is different. It has 5 pins and requires the motor with a matching 5 pin lead.
