Hi everyone,
I am the owner of a Beosound 9000 mkIII (connected to a transceiver and Beolab 18) for several months without encountering any issue, but yesterday I moved it delicately; since then I have the following PB:
- I am not able to use anymore the command panel (nothing happens if I push any button)
- I can only switch on (nothing else) the Beosound 9000 with the Beolab 4
- I can switch between cd's by using the buttons (corresponding to each cd) on the right side of the Beosound 9000.
- I can switch on/off the device by pushing the right button located on the bottom right of the Beosound 9000
Is there anything I can do (already unplugged it from 220V during several minutes): reset factory?
Thanks in advance for your help.
Regards,
Stephane
