Passive question
Hello all
Little question from me.
I had a Halloween party recently and someone turned up the link room with Bellini passive really loud when I was outside.
Since this the speakers sound muffled and I just thought they were blown.
Today I was listening to some music and turned the room up and noticed that it only goes up so far and stops.
I used to be able to turn it up quite loud but now it stops and doesn't go any further. It does not cut off.
Am I missing something here,
I have unplugged the passive from the audio master and tried different sources and it's still the same.
Help please
Seanie_230 wrote:
Hello all
Help please
Maybe your speaker is burned..if they bacause of that have higher impedance your maximum level is lower then before
/Tompa
Wild thought: Check the cables from and to. Check the connectors.
