Paring Eclipse to other WiSa speakers than BEOLAB
I have just bought the Harman Kardon Citation Surround for my Beovision Eclipse,
Just to test if it is possible.
But I cannot get it to work.
When I put the Eclipse in paring mode, the speakers react, and stop flashing, but the paring do not complete.
Any ideas? or should I just drop it?
From B&O homepage:
AN OPEN STANDARD
All WiSA-certified speakers offer interoperability and easy integration with other WiSA compliant TVs, A/V receivers or Blu-ray players.
Hej Emil,
do you have a source/a link for the user guide/owner manual?
The harman website is not very helpfull.
https://www.harmankardon.com/citation-series/CITATION+SURROUND.html?dwvar_CITATION%20SURROUND_color=Black-USA-Current#q=citation&start=1
The Manuel is there, very short though.
Thanks!
Just that I understand - did you purchase the two speakers on their own?
Or do you have the (sound)bar as well?
In the guide (very short indeed), they show that the speakers are connected to the bar.
Did you contact Harman and/or the dealer to clarify?
Yes I bought them on their own,
To pair with the Eclipse,
Did not ask anyone, just bought it to try.
I gave up,
Either Harmon Kardon, or B&O do not follow the open standard.
I guess it lays on Harman Kardon, but a mere guess.
Anyway makes you wonder about the LG Solution.
Now I have to think, if I really do need surround, because then the Beolab 17 seems to be the best choice.
