Hi
I'm having trouble re-pairing my Essence remote to my BS moment. I have had it paired in the past, and found it useful to have a (physically) remote stop/start/volume device.
Since I made a few changes to my setup, I can no longer get the remote to control the Moment like I used to, and I can't work out if I have a fault, or the new setup is the cause. I am on the latest Moment v2 firmware (updated last night).
My gear:
BV11 & Beoremote One (IR not BT)
BS Moment on latest firmware (updated last night)
Essence Remote
Beolab 18s configured in speaker groups on the BV11
Before the v2 software on the moment, and before I purchased a Beoremote One, I sed to be able to control the Moment via the essence remote (source, stop, start & volume)
Now, the Essence remote just does nothing. I have reset the BS Moment, unpaired my iPhone and re-paired it, changed Essence remote batteries. Changed it's mode to the "B' option, totally reset it with a very long pin press. Nothing!
So, now i'm wondering if the addition of the Beoremote One has affected things?
Would appreciate any thoughts or pointers if anyone has experience with a similar setup?
Many thanks in advance
Tom
