I'm trying since hours to control the volume of my Beolab 50 using the Beoremote One. What I read is that I needed an IR-eye, so I bought the "last" version (With join button) on Ebay. Here is the model:
Once received it, I connected it to the MIC/IR port in the master speaker, and set my Beoremote One in Beosound mode. But with this configuration, I was never able to control the volume of the speakers. I checked the wires order in the Eye, all are good, tried to change the connection port in the speaker, didn't work.
- Does this "Join" version works with Beolad 50?
- Does the Eye IR I bought from Ebay is simply not working?
- The IR eye is the right device I bought, or I have another solution to control BL50's volume with the beoremote one?
Any help is welcome.
