Transceiver Can be mounted on the outside wall.
I'm not aware of any B&O outdoor speakers. Any particular brand/product you would recommended?
And with this! the vox1 is not water proof, a good place to placed it is under the roof up side down.
beoperson:
I will definitely will look for these transparent boxes!
Are they made by B&O?
Yes you can get it at your dealer 🙂
Great, good to know that.
Thank you
lately i was on a yacht of a friend. i heard music playing in the cockpit, outside, exposed to spray from seawater, wind, rain,snow etc...
i asked the owner which speakers he used.
He choose for a very cheap set of speakers, some 5 years ago, as he found thne "yacht-adapted speakers" very expensive.
They still work after 5 years of exposure.......
