It's connected using cables I bought from Steve at Sound Heavenly.
The required cable is Old DIN Powerlink (for the BL5 end) to RJ45 Powerlink into the Core. Then you connect a traditional DIN Powerlink from the same Lab 5 to the other Lab 5.
Quite correct. My BL20s are :)Thanks Roger - very helpfull. A set of BL20 or BL18 via SPDIF driven by the Core would also be nice ;-) MM There is a tv - and there is a BV.
Don't want to hijack the thread but see attached for owners of Beolab 5's who want to connect to Core.
When will the BeoRemote One BT work on the Core?
Thanks David.
Now all we need is that ‘little extra’ information from Beowise.
It still is a question, how the BL5’s turn on.....when they need the CD command for opening the coax-in.
