Order Beosound Core with IR?
dear all,
Where can I order the IR version?
Cheers
Any B&O dealer?
The Core has IR support now - but in a transition period, a store might have both versions available. The IR support is great news for BL5 owners, too.
Roger
Roger
How can we tell the difference between the two variants ? I seem to remember it’s not obvious ...
No, I have 2 with IR. the DPL port is used but it still says DPL not IR.
I do have to say it works fine.
The old one became obsolete in mid-May (ie sold out from DK). The new one has the following type no. 3051 (replaces type no. 2797)
Roger
I am confused.
Is the older one an IR Core?
And the newer one wasn’t IR but is now?
Thanks,
AM
IR was a feature requested at the very first dealer meeting after the launch, but it took its time before they got around to launching it.
But just to be clear as mud: the old one did not have IR, the new and current one does have it. It is a very nice device now for owners of the BeoLab 5 as they can use the latest technology to stream and listen to music.
Roger
Hi
How does that work when a Beolab 5 needs a CD signal to use the SPDIF input?
B
Roger
Very interesting indeed.
I suppose, that you mean the possibility to connect ‘via digital’?
Could you write a few words about how to connect and control - does a small guide exist?
Normally you will have to use the CD command to open the BL5 for the digital connection.
So....how are the BL5’s activted, when connected to the Core?
Do you have to connect via ‘digital out’ and via PL from the Core as well?
