oneRemote backup battery?
Hi, I have an older oneRemote, picture here to aid identification, attached to my Beomaster 7000. We have had a couple of power cuts recently and the oneRemote has lost its settings. Does anyone know if it has a backup battery and if so is it replaceable?
Paul
Never heard that the device should have a backup battery.
But it is not unknown, that it looses its settings.
You will have to set it up again.
If you want a 100% answer, you could contact OneRemote directly.
Thanks will continue to reset
I have taken mine to pieces (to repair a loose connection) and there is definitely no backup battery, so you will have to set it up again according to the instructions.
EDIT:  Attached is a pdf of the instructions in case you don't have them.
Attachments (1)
Thanks Guy, have the instructions but a spare copy on the site is always useful.
