Older System--Can I hook up iPod?
Is there anyway I can hook up my iPod to this system? My dad gave it to me because he is upgrading, and I was hoping I wouldn't have to burn all my music onto CDs.
I have a BeoSound system from like early to mid ninties. I am not sure of the exact model number, but it looks identical to the current BeoSound 3200.
You will need a DIN to stereo minijack cable which you should use to connect your I-Pod to the AUX port on the B&O.
 The cables are widely available on Ebay or from Amazon
That's not an older system!
Many of us are using B&O systems on a daily basis that date back to the 1970's and earlier.
As Graham says, the appropriate leads are available on eBay or you can order them from somewhere like Maplin which is where I got mine.
 Simon
Depending on how much you want to spend you could also conside this iPod dock. You then control your iPod with your B&O remote.
iPod Dock
Craig🙂
