Odd Playmaker issue
Hi all
I just purchased a Playmaker which I use in the bedroom at the moment. I play music via airplay to the Playmaker. If the Playmaker is playing music and I switch the TV on in the lounge (LG OLED 55CS) the Playmaker immediately stops playing music. If the TV is on and I try to play music via airplay to the Playmaker then the Ipad cannot find the Playmaker. It is some type of clash. The Playmaker is connected to the WiFi.
Any ideas?
Ben
In my experience, the Playmaker has always been a bit 'flaky' when connected wirelessly. Dropouts and its disappearance from Airplay devices were frequent when I used mine wirelessly. If you search the older forums you will see many similar experiences.
The simplest solution is for a wired network connection - this has solved many glitches for other users. If cabling direct to your internet modem/router is difficult, consider using powerline network adaptor such as these:
Thanks Guy for the reply. I will have to try that as its too far to connect it to the router.
Otherwise it works really well and is quite useful.
Strange. I suppose that you could try hard-wiring the TV instead but you'd possibly need a powerline adaptor for that.
Alternatively, have a look at this old thread and maybe investigate some of the options including setting a static IP:
So I purchased a powered network adaptor. The adaptor has full bar signal.....connected the playmaker via Ethernet cable. It works initially then a couple of hours later when the TV has been used it has the same problem. As soon as the TV is switched on I can't connect anymore to the playmaker via Airplay. I can see the playmaker on Apple Music but it says cannot connect. If I turn the TV off the playmaker still doesn't work, I have to reboot the playmaker each time. I have tried to change the channel used on the Wifi router but it made no difference.
Ok I bought a WiFi extender by mistake....I now understand what you mean so what I have done is I have taken the playmaker to the room where the router is and have connected the playmaker via an Ethernet cable directly to the router, connected speakers and I still have the same issue! :(
Software is up to date, no idea if its a MK1 or Mk2
Its a Mk 1, I have given up on it to be honest and have asked the seller (reseller of B&O equipment) to take it back and refund me.
Thank you though for all the advice, perhaps a MK2 would work better.
