Hello,
Have you seen this?
I think that B&O has to react soon. And you?
Hello,
Have you seen this?
"Warning: Important Safety Notice
Examination of Loewe picture tube TV sets from the years of production 1999 to 2001, and of TV sets made by AHB
Safety and reliability of the products have the highest priority at Loewe. In the framework of continuous quality checks it was discovered that, in picture tube TV sets from the production period March 1999 to October 2001, faults could arise at certain soldered points which could lead to overheating of the set and, in the worst case, to a danger of fire.
Only 100 Hz picture tube TV sets made by Loewe, and certain 100 Hz picture tube sets made by AHB are affected.
These sets are now between 6 and 8 years old.
To avoid any risks for our customers, Loewe points out that these TV sets should be checked by an authorised dealership as a precautionary measure. This will involve checking the affected soldered-riveted joint and re-soldering. This precautionary check has been carried out over the past three years at every repair carried out in Loewe workshops.
Loewe recommends that customers should have the check made as soon as possible and not to operate the set until it has been checked.
You can check here whether your set is affected by this campaign."
And Data transfer though electric socket. Not more problems when you need a new link somewhere and you just didn't think about it when you built your house!!!!!!!
And it happened to me.
