Normal CPU temperature for BeoMedia 1
Dear freinds,
Could anyone advise about normal CPU temperature for BeoMedia 1 in use, for exemple when watching flash web sites?
Mine is around 35 degrees Celsius when idle and reaches 62 when in intensive use, like watching hq photos and listening N.Music in the same time, or watching videos...
Kind regards!
Hi Arcarius,
62 degrees Celsius is nothing to be mentioned for a CPU at all. Most of them are allowed to get much hotter.
Maybe double check if some dust closed the headsink or the ways air should circulise.
But as I do not know which CPU is build in the BeoMedia 1 I do not know the specifications of it.
Cheers,
Many thanks
