I said to myself I wont be stubborn anymore :) and made
deal with my friend who run's HI END shop to take couple of non B&O sub's to try
We made a deal, he will give me 3-4 sub's ( different quality and price range ) to try for couple of days.
First one is cheep Yamaha, which determine my statement that sub is not
good for music, but I will try 3 more and than I will make my final
statement.
Friend were told me that he had surprise for me on the end which will change my opinion. I'm not denying, I'm patient :)
I will report you for each of sub's, and keep you up to date :)
All sub's are active
This Yamaha SW030
is slow, no dynamic at all, bumpy and doesn't go that low. Probably for
movies is good, but I will not test it on movies, only for music.
Fine for jazz and classical, but you can not listen Spor at all :) when
you listen dynamic electronic music you hear, most of the time, only low
buzz which is really annoying ...
And on low volume not that deep, which is important for sub.
Conclusion : Yamaha is for low grade home theatre setup, for movies and some tv.
Next one is Monitor Audio MSW 10
I'll let you know my impression with this sub 🙂
