My beo4 doesn't have a Pc button.How can I remote then my beoport to enjoy Nmusic and N radio through beoport converter on my beocener 2300?
No pc button on Beo4
The PC Button is no hardware button. It can be added to the list of comands that appear when you press the LIST button on the remote. To use the PC Button you first have to add it to the list of commands. To do so, you should press the ON/OFF button (Red dot) and simultaniously press the LIST button. A submenu on the display appears saying "add". Press GO and scroll untill the command "PC" appears on the display. Press the GO button and there you have your PC button.
BC2300 is not Beoport compatible - see here:
/forum/general-discussion-and-questions/bc-2300-and-beoport#post-1857083
There's no such a" button" on my beo4 add list..
I think there is a possibility to simulate some buttons like nmusic or nradio with L-phono ,funny is that I can remote my bc2300 radio and cd player with this beo4 as well but I can't remote the nmusic and nradio.
It´s no "funny" about that.., Nmusic and Nradio doesn't excist then your remote was made, but you can use Phono as N.Radio and Atape2
as N.Music but BC2300 does not support Beoport !
/Tompa
