SoundsGood wrote:
Thanks for the hint ...
I set-up a Plex Media Server (DLNA enabled on my Mac mini (I use the Mac as my Music Server ) and give the Beo App access to the Server. Now I can control my Music with the Beo App. But the Player on the Harmony is the LG Player with a horrible Interface ;-)
Any Hint about to Hide the LG default Apps (Galerie, Video ...), I could delete all other installed Apps ..
Best Thomas
and Greetings from Hamburg
If you stream like Carolpa writes, you use the Harmony in audio mode.
The plan is, that the Harmony - with a coming update - should be able to display some infos/metadata on the screen in audio mode.
However, when this will happen and exactly how is still unknown.
Maybe you are expecting a media player from B&O (like e.g. In the BV11) on the screen of the tv.
There is no such - you have the LG-one (which you find ‘horrible’).
I guess it is a matter of which ‘player’ you choose as end point for the DLNA stream!
Maybe you can install another media player from the LG app store, that suits your needs better (e.g. a Plex app).......if you want to use the screen/see metadata, coverpics etc there.
I am not familiar with what you can install - but that could be googled.
Hope this helps.
