No Bass from Beolab 19 connected to Beovision 11 WISA
Hello,
was wondering if there is anyone that may be able to help me. I have a pair of beolab 18's and a beolab 19 connected to my beovision 11 with WISA.
The 18's are working as expected but the beolab 19 has no bass. When I go through the menu of the beovision it shows that beolab 19 is connected and I can hear the static sound coming from the beolab 19 as well, however when playing youtube music videos or any other video there is no sound at all.
The settings of the 19 are set as follows
Gain max
LP Filter off
Phase 180
pos w
wireless
L+R
Any help is appreciated.
Did you assign a speaker role to the BL19 ? It should be set to subwoofer
Hi yes I did assign a roleπŸ˜’
Did you resolve the issue yet?
How is your setup for speakers in the BV11?
My guess is that you might have overseen something.
When playing a source like YT, you are also listening to the speaker group that includes the BL19?
If all has been properly setup and still no bass, try a PL connection to check if BL19 kicks in, if not then something is wrong with the BL19.
Hope this helps
Thank you so much for you assistance Fantastic,
Beolab 19 is given the role as sub rear on the beovision and when I highlight it I do hear it make a sonar like type of sound. Or when I go the speaker connections menu and select it there it makes a static sound. setup is 7.1 surround.
However when playing music or regular tv nothing from it.
I have beolab 5's as front left and right connected to the beovision and beolab 3's as left and right  wide as well, and beolab 18's rear left and right.... over kill but regardless don't understand why bass is not working on beolab 19.
I am suspecting something is wrong with beolab 19....is there anyway I can check the firmware on it ? I did see some posts about updating the firmware via transmitter 1 but i don't have one.
Thanks again.
Oh also I did try PL connection and result was the same.
Thanks again.
Thank you it worked!
sorry quick question I will remove the 18's and 19 completely from beovision and connect it to Beosound 5 encore. The question i have how do I connect the 19? do I just connect it to one of the 18's?
Thank you i understand now. sorry quick question I will remove the 18's and 19 completely from beovision and connect it to Beosound 5 encore. The question i have how do I connect the 19? do I just connect it to one of the 18's?
So what I will be doing is to remove the beolab 18's and 19 from the beovision and use them on my music system only.
One question I have is if I have beousound 5 encore connected to the beolab 18's how do I connect the beolab 19? does it just get connected to one of the beolab 18s?
