No AUX at Beoplay A1 second Gen
Hi, I just bought a Beoplay A1 second Gen - unfortunately the second Gen A1 is missing the 3,5mm-Aux-connector. It only has a USB-C-Connector. Bluetooth works fine, but isn't realy an option to me for several reasons.
So I tried to plug my USB-C-to-3,5-Adapter I use for my IPad-Air to the Beoplay A1 - which didn't work. USB-C-Plugs differ from plug to plug, so my question is: Is a working USB-C-to-3,5mm-Adapter available somewhere?
One tip I can give for connecting the iPad with a cable to the A1 is to just use USB all the way.
  • If your iPad has a USB-C connector, a direct USB-C to USB-C cable will do the trick.
  • In case of a Lightning connector, your best bet is Apple's Lightning to USB-A adapter and then a USB-A to USB-C cable (direct Lightning to USB-C cable won't work).
The problem with finding a compatible 3,5 mm to USB dongle is that the A1 is not a USB host device (like a computer, smartphone or tablet) but instead a peripheral – which the dongles are usually too. This results in a situation where neither device knows how to talk to one another.
Maybe if you list your specific use cases we could provide alternative suggestions?
Human interface designer at Bang & Olufsen.
Thank you! In my opinion you described the Problem perfectly. To give an update:
I also asked B&O for help - there I was told to buy AUX-to-USB-C-Adapter with DAC. I did so - and it didn't work. Even with DAC. The only way I think COULD work, is using the Behringer UCA222; it translates the analog AUX signal, digitizes it and sends it to USB - which works, when being connected to a computer and might also work, when being connected to the A1, as the A1 in that moment does more or less the same, as a computer does.
Specific use: I own a beautiful, perfectly maintained, white Beosystem 7000 (receiver and record player, controlled by a Beolink5000) with an original white Beolab2 und two Beolob8000. From the Tape-Connector of the Receiver I grabbed a Line-Out-Signal and plugged 2 Cinch-Y-Connectors. Two of the Connectors lead to an AUX-cable, which leads to another room, where a modern Beolit20 is attached - via AUX. Perfect sound!
The other two Connectors lead to a BT1100-Sennheiser-Bluetooth-Transmitter, which sends the signal to my A1. The Problem is: There is small latency (half a second, maybe) between the A1, and the Beolab2/Beolab8000/Beolit20. Mostly I can deal with that. Often enough I don't. So I am searching for a solution to avoid the latency, which would work best, if there is a way to Connect the A1 via USB to my system.
As far as I can say, I could either try to give a similar latency to the rest of the eqipment - which exceeds my technial knowledge - or try to find a 1st-Gen-A1-Speaker, which still had AUX - what I really don't want to.
The whole Equipment works fine and sounds great, i even attached a device to my Beomaster, which reveives Bluetooth and a Converter, to create an AUX-Signal from the Toslink-Signal of my new TV.
Sounds a bit insane, all in all, but that's B&O...
I am almost certain this will not work either – the UCA222 is a peripheral device as well, and requires a host device to work. Male USB-A connector (and permanently wired at that) is a telltale sign of this. You would need to connect it to a computer along with the A1, and then run a piece of software that will loop the audio from the audio input to the A1 (some computers also have built-in line inputs, in which case you wouldn't need an external ADC).
You could also do this with a very small system like a Raspberry Pi (with an appropriate ADC such as HiFiBerry DAC+ ADC, or a USB ADC).
There will be some latency involved with this as the audio makes a round trip through the computer's operating system, but it may vary based on the exact hardware and software being used.
Again: Thank you for your assessment. I guess finding a small peace of hardware won't be the problem, I am wondering whether there is already software that converts an analog audio signal into a digital one automatically & permanently and outputs it. Anyway: Thank you.
And.. I just found this peace of Hardware: ELV AD100. Do you think that might work?
Thank you - the device digitizes the AUX-Signal, but the Signal via SPID/F / Coax is still not suitable for USB-C at my BeoplayA1 and there is no converter as well.
