tph wrote:
One tip I can give for connecting the iPad with a cable to the A1 is to just use USB all the way.
The problem with finding a compatible 3,5 mm to USB dongle is that the A1 is not a USB host device (like a computer, smartphone or tablet) but instead a peripheral – which the dongles are usually too. This results in a situation where neither device knows how to talk to one another.
Maybe if you list your specific use cases we could provide alternative suggestions?
Thank you! In my opinion you described the Problem perfectly. To give an update:
I also asked B&O for help - there I was told to buy AUX-to-USB-C-Adapter with DAC. I did so - and it didn't work. Even with DAC. The only way I think COULD work, is using the Behringer UCA222; it translates the analog AUX signal, digitizes it and sends it to USB - which works, when being connected to a computer and might also work, when being connected to the A1, as the A1 in that moment does more or less the same, as a computer does.
Specific use: I own a beautiful, perfectly maintained, white Beosystem 7000 (receiver and record player, controlled by a Beolink5000) with an original white Beolab2 und two Beolob8000. From the Tape-Connector of the Receiver I grabbed a Line-Out-Signal and plugged 2 Cinch-Y-Connectors. Two of the Connectors lead to an AUX-cable, which leads to another room, where a modern Beolit20 is attached - via AUX. Perfect sound!
The other two Connectors lead to a BT1100-Sennheiser-Bluetooth-Transmitter, which sends the signal to my A1. The Problem is: There is small latency (half a second, maybe) between the A1, and the Beolab2/Beolab8000/Beolit20. Mostly I can deal with that. Often enough I don't. So I am searching for a solution to avoid the latency, which would work best, if there is a way to Connect the A1 via USB to my system.
As far as I can say, I could either try to give a similar latency to the rest of the eqipment - which exceeds my technial knowledge - or try to find a 1st-Gen-A1-Speaker, which still had AUX - what I really don't want to.
The whole Equipment works fine and sounds great, i even attached a device to my Beomaster, which reveives Bluetooth and a Converter, to create an AUX-Signal from the Toslink-Signal of my new TV.
Sounds a bit insane, all in all, but that's B&O...
