NL/ML Converter - versions?
How many different hardware versions of the converter exists - and what are the differences?
Item number: 1179011
Type number: 1790
Product HW info
Name: BeoLink Converter NL/ML
HW variant: Version F
SmallEngine HW info HWID0
PCB version: E
Variant: 8004752
BOM: version K
Configuration word: 2120
This is the only variant known to me.
Note: the first BLC had some connections hidden behind stickers, but were identical to the later ones.
It seems the BLGW is another variant.
I have seen several units marked as NL/ML Converters that had been turned into BLGW units. After spending much time trying to do resets and various means of establishing a connection, the way I realized this was by using the Ping app, in which the devices appeared as BLGW.
@Carolpa and beojeff
Thanks!
By the way - which woiuld be the latest manual/guide for the converter?
I have a version 1.4.
How do you transform the NL/ML converter into a BLGW unit? Just a software update?
Is there anyone that have tried to load BLGW software NL/ML converter? How did you get the converter to load new software?
Any news on this topic?
For the moment I have a spare  Beolink NL / ML Converter (does not find Software updates anymore - servers down?).
So I think about turning it into a BLGW.
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
Hi Ralf,
did you get any respone and updated an NL/ML into an BLGW ?
Kind Regards
Tom
I would also be interested if there is a way to turn an NL/ML Converter into a BLGW.
