I have a Beolit 707 which has an all-black finish. However the finish on the loudspeaker panel and corresponding back panel has me puzzled.
Both panels are finished in matt black, but ever since I’ve had the radio I’ve always wondered about the slightly sticky feel this finish has and whether it’s a genuine factory finish. I’m pretty sure it can’t be a ‘Nextel’ finish.
If I remove the panels the reverse side reveals a royal/turquoise blue plastic which is I believe one of the standard colours for this model. Is this how B&O manufactured these panels by simply covering another coloured panel, or is it likely to be a DIY conversion? If so is there a way of removing the black colour without damaging the original coloured plastic? Some of the blue colour does come through on some of the panel edges and corners through wear.
Also can anyone help me obtain clips for the internal ferrite rod aerial as they are both broken.
I also have a Beomaster 3000-2 which needs a new light for the front ‘Stereo’ beacon, can anyone help?
Thank you
Normal 0 false false false EN-GB X-NONE X-NONE
