Thanks for the reply - this has helped and I am now further along.
I have figured out the following;
The Beo4 remote control that came with the TV came from a hotel, as did the TV, this means the remote does not have all the usual buttons.
Thankfully, I have another Beo4, from my BeoSound, so I was able to use that which helped.
I have done a reset to default, and have added some soft buttons to the list on my old Beo4 - its quite an old version I have.
I have a few questions, if anyone is able to help;
1) My TV does not have an HDMI input, however the red lettering on the display does show HDMI when I select one of the input on my Beo4 (V.Tape) - any ideas why this would say HDMI?
2) I want to connect a SKY Q mini box, via either HDMI to DVI, and use the DVI connector on the BeoVision, or, as I do not yet have a HDMI to DVI cable, use AV out to Composite and use the Camera input on the side of the TV, as a test, while I wait for the DVI cable to come. Do I need to set the Connection in the Menu on the TV to HD for this to work, the options are DVI-I, YPB... or None?
3) on my hotel version Beo4 remote, there is no hard button for "List" - is there any way to use the List functionality on that remote?
Thanks,
