New software BV11
It says not what the change is...maybe Beolab 90 as option!?
That's probably the only difference. I've received the same update as well. I noticed in the technical sound guide that a beovision v1/11/avant and bsys4 can control beolab 90 over powerlink (and wisa probably). Quite interesting I think, since I thought B&O gave up on the data link features of powerlink.
The BSys4/the Avant need to know, that the BL90'ies are used in the setup anyway.
I haven't written the update to the BeoVision Technical Sound Guide yet - it's coming, but not within the next couple of weeks I expect...
If you look in the Speaker Groups menu, you'll see a new item called "Speaker Preset" - this automates the preset control of the BeoLab 90.
When you make a preset on the BL90, you assign it a number in the BL90 App. To get a particular Speaker Group on the BeoVision to select that preset, you enter the number in the Speaker Preset menu on the TV.
Cheers
-geoff
PLEASE READ before sending me a Personal Message.
If you have questions about or problems with B&O equipment, these should be directed through your dealer and/or B&O's Customer Service department.
I cannot be a "short circuit", bypassing these communication channels.
-geoff
My V1-32 has gotten the update too.
I could have the BL90'ies in our guest-room.
No excuses anymore ;-)))
Except that there would not be much room for the guests, then ;(((
Would have to run them in 'single guy-one chair-very narrow beam-mode'.
If you treat your guests with a pair of BL90s in their room and they then complain about lack of room, you are inviting the wrong guests! 😁
I'm sure you'd have an endless stream of volunteer guests from here who would not complain... In fact, can I be first to volunteer please 😕
Martin.
I'll have to call 'Struer', then - to send me a pair for testing in a small room :-)
https://www.facebook.com/Bang.Olufsen.Ealing/photos/a.10151951856165972.1073741832.98711300971/10153721065670972/?type=3&theater
Philips Hue integration :)
MARKFS wrote:
Very Nice! Is that part of the new software? Is the Gateway needed? How is it done?
Razlaw wrote:
Yes, just how is it done? Looks really interesting!
Graham
