New rear speakers ?
Hi, I am about to get new rear speakers for my system. I have been looking at both the BeoLab 3s and the BeoLab 4s but I am not 100% satisfied with any of them.
Does anyone know if there will be some new speakers released this autumn ?
Best regards
Hans
If you weren't happy with BeoLab 3's as rears - were they switched on?!! ๐Ÿ˜ฎ
I can only really suggest BeoLab 9 as rears if the 3's didn't float your boat. What are you using as fronts?
Lee
๐Ÿ™‚
Not happy with Bl3 at rear?!?!?!?!? ๐Ÿ˜‰ I don't think that anything between the 3's and the 9's would be released anytime soon... So buy BL5, or check that it wasn't your 5.1 encoding that was not good enough...
BeoLab 3s are perfect as rears if you've got something like BeoLab 3s, 9s or 5s as fronts, as they give you all the advantages of the acoustic lens (ie, not just blurting sound out into the room in a largely uncontrolled fashion like most loudspeakers), but they also give you enough volume output for any rear-channel application and are immensely flexible (rear speakers should always be placed higher up).
I have  BL 8000 as surround and BL4s as rear surround; I also have a pair of BL3s in a bedroom for listening. .
If you are comparing things to the BL5s you will not be happy with anything else.
I used the BL8000s mostly because of the way they looked and they fit better with my decor.
I think when you're looking at BL3 and up it's a matter of taste and aesthetics as much as anything. . . assuming of course you're using BL 5s in the front
Hi, thanks for all comments. I'm sorry I left out some information in my post.
 - I have Beolab 6000 and a Beolab 2 as sub. Everything is bought in 2004. The 6000 most for the design which I think fits my room perfect. With the Beolab 2 I also think the sound is really, really good. Dreaming of BeoLab 5s in the front some day of course.
- The reason I am not satisfied with 3s or 4s is the design. Since it is 250 km to my nearest dealer I have not have the opportunity to listen to either one of them.
Please keep on posting.
Best regards
Hans
Save up and get a pair of BeoLab 5s as fronts, and use your BeoLab 6000s as rears! You could even sell or part-exchange your BeoLab 2 to bring down the cost of a pair of BeoLab 5s. Look for an ex-demo pair too!
I suggest the same thing i will do within a few weeks:
Put the 6000 from front to rear and get 8000ยดs as front speakers. they match the 6000 very good. what tv do u use?
I have Lab 3s front with a Lab 2 and Lab 4s rear...and my set-up is great imho. My Lab 4s are fitted facing downwards about 8 ft up on the back wall above the sofa. For watching tv films, videos and dvds the Lab 4s are perfect...if however i had wanted to listen to music on Speaker 4 Mode then i would have bought another pair of Lab 3s for rear...although i do sometimes play Speaker 4 Mode at low/medium volume levels and it still sounds good to us!
I think putting the 6000s in the back and getting a pair of 8000s as front speakers would be a good thing to do, especially as you already have a sub. An alternative would be a second pair of BL6000...
Register to access the forums, reference material, and exclusive member benefits โ€” including our monthly prize draw.
