New Member - Beolab 5 and BL3 to non B&O Receiver (Onkyo?) - Advice please
Hi guys
Firstly great forum you have here, have been reading it for a while before I finally decided to sign up and post up some questions of my own.
I have just purchased a set of Beolab 5's and Beolab 3's, no center speaker yet as I have read on numerous threads here about the awesome "phantom center" of the BL5's! I have also purchased the beautiful Beosound 5!
Anyways let me cut to the point:
- I want to connect the BL5's and BL3's to a non B&O receiver which I have not yet purchased.
- I will be connecting a media center PC to this receiver and playing HD content (blu-rays etc) through this, as well as a Beosound 5.
- I am battling to understand how I would connect the speakers up to the receiver as I am still familiarising myself with B&O speaker technology. e.g. "Active speakers" and how the receiver needs to support the correct voltage etc., and also what wires I will need as they cannot be powerlink <--> powerlink due to the receiver being non b&o.
Can anyone please advise me on the above, and also recommend a good receiver which has:
- HDMI inputs
- supports all surround formats (including the uncompressed DTS-HD, True HD etc)
- supports "active speaker" technology on the Beolab 5's and 3's which turn them on and off automatically? Onkyo seems to be the name thrown around the forum,will this model fit the bill? (PR-SC5509 http://www.uk.onkyo.com/en/products/pr-sc5509-58251.html supposedly their flagship model )
Please excuse my lack of knowledge on the matter!
Looking forward to your advice and spending more time here on the forum!:)
P.S. Here is the Onkyo PR-SC5509 back panel image as mentioned above:
I have a very similar setup currently.  I have this: http://www.anthemav.com/products/anthem-statement/processor/d-2v  as my A/V processor connected to Beolab 5 fronts and 3s in the rear.  That Onkyo looks very similar
The speakers connect to the preouts on the processor.  I do not think you can use the balanced outs because of the voltage.  The lab 5s are connected simply using regular RCA cable to the line in on the lab 5s.  For the 3s, you would need an RCA to powerlink cable which are readily availiable.  I got mine from Sounds Heavenly off this website.
The lab 3s will power on automatically once they get a line in signal from the processor.  The 5s are a little more complex.  You will need to turn them on using a B&O remote, then they will simply play once they get a signal.  You also have to change option settings on the lab 5s which is easy enough to do.
You will need to set the proper volume on the Beolab 5s as well.  You would use the test tone feature on the processor and make sure all of the tones are the same volume.
It's all easy to do but it took some research on my part to get it done.  It's an awesome setup, movies sound better than the theater!  Music using a good surround mode is enveloping.  There is some good info buried in the forums here as well on doing this.
Hope this helps
Oh, and furthermore,
When setting up the speaker configurations on the processor, you would set the lab 5s to "large" and the lab 3s to "small".  You would select "none" for center and subwoofer.  The phantom center channel using the lab 5s is very good although I am contemplating getting a center channel.  The subwoofers in the lab 5s are simply awesome.
If the processor has some kind of bass management setup, skip it.  Use the calibration feature on the Beolab 5s instead.
Hi beoinbuff
Thanks for the quick reponse and for sharing your knowledge with me - very much appreciated!
Regarding the RCA --> Line Cables, can I not connect it via Digital Out to the AV receiver instead of LINE?
Also will I need to "syncr" cable at all? Or is that only necessary if I use the digital out instead of LINE? Suppose I would also have to purchase this seperately.
It's a shame the Beolab 5's have to be turned on by their own remote, just introduces more remotes :( I was hoping there was a way to get the BL5's to turn on automatically like the BL3's.
Have read a lot of good words about Sounds Heavenly here on the forum! If I ever needed any more cables in the future I will be sure to give him a shout, however the B&O dealer offered to provide me with the cables I need for now when they ship the speakers.
P.S. Getting a bit OT, what center speaker will you be looking at? BeoLab 7-1/7-2/7-6? Do they work with non B&O receiver/tv? 😁
I have an Onkyo, connected to BL 8000 front, BL 4000 center, and 2 non coms passive as surround, works like a charm, I used the automatic calibration on the Onkyo, but as you use BL 5s you can set it yourself. BLs are connected to the preouts and the passives to the amped.
Retired
Printing machine technician
Rock and Roll music
Collecting Vinyl
Thanks for confirming :) Looking forward to setting this up once I find out the right cables I need and if there is any way to power the BL5's on with the AV Receiver :)
There is one point that I dont like with my Onkyo.
The preouts are, 270 mV/470 Ohms, this means that I cant drive my BLs to full volume, its good enough for my dayly use but I cant get the volume up to where the windows starts vibrating, Wtih my Beosound 3000 they go way higher to the limit where the protection circuit in the BL 8000 kick in (lowers the bass level), so if you did not buy your Onkyo yet, think about it.
Once in a while I play some Rock to get my brain blowed out, I do that on my BM 4000 with S45 and Bvox 3000 panels. I cant do that with the 8000/Onkyo
Retired
Rock and Roll music
Collecting Vinyl
Hmm thanks for bringing that up! It just made me reconsider my decision. Was quite set on the Onkyo PR-SC5509.
However, I see the following specs on the data sheet for that particular receiver:
Maximum RCA Output Level and Impedance
5.5 V/470 Ω (Pre out)
Does the 5.5V mean I will be able to drive them to full volume? Which figure am I looking at for my BL5's to drive them hard enough (full?) ?
Thanks once again!
As the 5509 has 1 to 5.5 V  on the preouts, there should be no problem, the 708 has only 270 mV to 4.5 V  . So I think it should be OK.
Audiophiles looks for at least 1 V in the preouts, I dont know to much about it and why, but thats what I've found reading, also several users with amps with preouts with 1 V has no problems driving big Klimsch and simular aktive speakers.
So dont dont kill me if it doesn't work 😂
Retired
Rock and Roll music
Collecting Vinyl
 Haha don't worry! No one to blame but myself 😎
I just thought/expected for the price of that particular receiver that it would be able to drive the BL5's to full capacity! Hopefully what you say is right :)
Maybe some of the more knowledgable members will be able to enlighten us!
Need to make my decision by Monday as the BL's are getting shipped on Tuesday, so I'm hoping to inlcude them in the same shipment.
Thanks!!
P.S. Seriously considering getting the dealer to add a BL7-2 in the shipment for center speaker to complete the setup!
