New Lighting Solutions
Hi All,
I’m bracing myself for a barrage of’ we’ve been through this 100 times’!
However, I was wondering if there have been any developments in the Beo4/A9 controllable lighting solution arena?
I’ve ready many threads on the subject, listing all the various solutions out there, e.g. Lutron Rania, JBMedia etc etc. I was just hoping that there may be something that ticks all the boxes:
1. Reasonably priced (£225 for a single gang B&O compatible Rania when the non-B&O version is less than half price just annoys me!)
2. Good quality, both inherently and to the touch
3. A direct replacement of a standard UK wall switch with no additional wiring or work necessary.
4. Comes in one gang and two gang versions (I believe the Lutron B&O Rania comes in one gang only – please correct me if I’m wrong)
5. Good response to a Beo4 – I’m just not used to having to point a remote control anymore!
Any advice would be gratefully received
You are correct, there has been much discussion on this subject over the years particular after B&O stopped selling the LC2.
If you want to control any of these lighting products other than the B&O compatible Lutron and similar with the Beo4 without a converter then the options still remain small. However if you are willing to move to using a Beo5, then your options increase dramatically including control of a double Lutron Rania (non B&O compatible version) because you can programme the Beo5 with 3rd party IR control.
Aludim or Bossdim (which are actually the same product) can be a perfect replacement for the LC2.
Thanks for the tip PhilLondon but I'm more looking for light switches on the walls rather than a dimmer for a table lamp etc
Thanks for your help none the less
This is a danish standard size Beo4/5 compatible dimmer for wallmounting. Unfortunately this is the only solution I know that is this small. I don't know about how good it is at receiving the signal, but these would definitely be my choice.
It is also touch sensitive.
You can read more about it here: http://shop.oneremote.dk/catalog/product_info.php?products_id=2456&osCsid=q9ihtki0omc3cj8sb2akq5o1j7
Although other danish webshops has them for half the price of the above link.
Looks promising Toubro!!
Does anyone have any further information about them?
Anyone already use them?
Do they tick my boxes (especially easy installation)?
Looks like we may have a winner!
Bosscom have just come out with the BossDim Wall!
Looks like it ticks all the boxes except the size which I believe is a little smaller than UK standard.
You have to be a bit carefull as well as in the UK the wiring is different and does not necessaraly give you access to both the Neutral and the Live cables.
I agree with Phil in that UK house wiring electrical standards do not normally have a "neutral" wire in the switch box.
Equally most recently designed dimmers do not need a neutral wire because they are wired "inline" in the live connection.
For goodness sake B&O you must see there is a demand for lighting control, so why not simply produce an LC3?
