More info:
More info:
This was made available in the Apple store last month and is a very nice App. However, it is only useable with the Masterlink Gateway, but you can use the demo mode to see how it is intended to work.
Keith, you're talking about the original B&O iPhone App.
This one is different and works with Beoport and Linkplayer on a Mac.
For the moment it only controls the sources as accessed on the Mac, it is not yet a remote control for all the B&O in your house.
There is a whole thread in the Mac forum.
Thanks for that.. I missed that one, not being a MAC user.
If you need "a remote control for all the B&O in your house", use this one:
It doesn't have the B&O codes in its database which means it needs to learn all the codes first (by pointing the Beo4 to it and send button by button). Once you created the buttons and learned the codes it works perfectly.
Ralf
